Tire question
Old May 12, 2006 | 09:15 PM
s2ktarga's Avatar
Default Tire question
Can this setup be had on stock suspension?
and stock wheels (ap2)
Thanks in advance
Blessings
Old May 15, 2006 | 09:00 AM
mic_crispy's Avatar
no
Old May 15, 2006 | 09:08 AM
s2ktarga's Avatar
roll the fender? or change wheels or both?
Old May 15, 2006 | 10:52 AM
mic_crispy's Avatar
well its kinda a tricky question... from what i understand if you wanted to run a 285 tire you would prob want a 10" wide rim... and givin the tricky offset of the car, finding 10" wide rims that will work is very difficult and exspensive. not to mention that you would have to prob run a large amount of negative camber, which would actually decrease your contact patch.
how come you want such large tires anyway? my suggestion would be to run 225 / 255 on your stock ap2 rims...
Old May 15, 2006 | 12:03 PM
s2ktarga's Avatar
Should I do that with a softer compound?
Old May 15, 2006 | 02:05 PM
IIGQ4U's Avatar
What are you planning to do? Do you intend to track the car?
Old May 15, 2006 | 05:42 PM
s2ktarga's Avatar
Yeah tracking it.
Old May 15, 2006 | 05:44 PM
IIGQ4U's Avatar
Then you will want a softer compound.
I saw a guy around here with 285's all the way around but I have no clue what he did to run that width.
Why not start with a 225 255?
Old May 15, 2006 | 06:35 PM
krazik's Avatar
Administrator
omg where did you get this info?
Old May 15, 2006 | 06:45 PM
mic_crispy's Avatar
just what i have deduced from reading off the forums..... if anything is incorrect fill free to correct!
