Tires rubbing the spring perch in the front.
Old Jan 15, 2009 | 09:00 AM
JeremyStone's Avatar
Default Tires rubbing the spring perch in the front.
Only under full lock as far as I can tell. These are only going to be used on track. So I don't see myself using full lock too often. Is this dangerous?
Wheels are 17 x 9 +63.
Tires are 245/45/17
Stock suspension.
Old Jan 16, 2009 | 01:52 PM
FormulaRedline's Avatar
How bad is it? Keep in mind the suspension moves up and inwards as it compresses.
Old Jan 16, 2009 | 02:15 PM
9kI4's Avatar
Are you sure it's the tires?
I run the same size wheels, and I can't go full lock without rubbing the upper control arm with the wheel.
Old Jan 16, 2009 | 04:06 PM
AnthonyD1978's Avatar
Tires are 245/45/17
Stock suspension.
if it's only at full lock you should be ok, but make sure it doesn't rub when you're not at full lock and the suspension is traveling up and down too.
it's a combo of your offset, tire size, and your stock suspension....best solution would be to upgrade to coilovers...they will have a smaller perch. cheapest solution will be to go with a narrower tire.
Old Jan 16, 2009 | 04:13 PM
Yeah, I think it is the wheel. It's crazy that when the wheel is straight it feels like there is a ton of room back there.
Old Jan 16, 2009 | 04:17 PM
while you could fix it with getting a lower offset wheel....a different tire size or coilovers will fix it too....good excuse to pick up some coilovers if you ask me.
Old Jan 16, 2009 | 04:47 PM
haha yeah.
I just tested it. It hit on the rim protector lip on the tire. It only hit on the drivers side, which is the side I turned to coming out of the driveway. So either my driveway puts a funky angle on the car, or I need to lose weight.
I have an autocross on a really bumpy lot tomorrow, so that should be a good test before my first trip to Sebring.
Old Jan 17, 2009 | 03:01 PM
neurotic's Avatar
Old Jan 17, 2009 | 03:43 PM
I got a lot of fender tab rub too though, so spacers would make that worse also.
Results from today's autocross. Fender liner / fender tab tire rub. Tire rub on the spring perch and wheel to control arm contact.
I think I am just going to drive it as is and try to avoid full lock. Sometimes that's not easy in autocross though.
deepbluejh
Jun 25, 2014 02:45 PM
Rev9K27
Apr 7, 2012 09:51 AM
ewin
Feb 1, 2012 09:05 PM
legendr34
Jun 22, 2001 09:30 AM
viscreal2000
Dec 17, 2000 12:57 AM
