Too much camber
Setup
03
KWV3 w original springs (~515 f/r)
stock fsb/rsb
17x8 F, 17x9 R
BFG R1 225/255
F castor 6.45
camber -4.25!!!
toe 0
Without getting lost in the details, I have a track day in two days and won't be able to get the alignment adjusted. Is this camber going to quickly destroy the inside edge of the front tire?
I know camber is determined by testing with a pyrometer (which I do), I know this setup isn't ideal, I now ideal varies depending on setup/driving style... etc etc... but for this weekend it's what I'm stuck with.
Thanks
03
stock fsb/rsb
17x8 F, 17x9 R
BFG R1 225/255
F castor 6.45
camber -4.25!!!
toe 0
Thanks
You'll heat cycle out the tires before you wear out the inside. Just corner hard....
Also, lots of tracks have trackside tire people. If you can get the fronts flipped inside out midway through the weekend, even better.
BTW, this is a prime reason to have a square setup. Ability to rotate tires almost pays for the cost of extra wheels.
