Too much camber
Old Nov 1, 2012 | 01:37 PM
turbo8765's Avatar
Default Too much camber
Setup
03
KWV3 w original springs (~515 f/r)
stock fsb/rsb
17x8 F, 17x9 R
BFG R1 225/255
F castor 6.45
camber -4.25!!!
toe 0
Without getting lost in the details, I have a track day in two days and won't be able to get the alignment adjusted. Is this camber going to quickly destroy the inside edge of the front tire?
I know camber is determined by testing with a pyrometer (which I do), I know this setup isn't ideal, I now ideal varies depending on setup/driving style... etc etc... but for this weekend it's what I'm stuck with.
Thanks
Old Nov 1, 2012 | 02:45 PM
CKit's Avatar
You'll heat cycle out the tires before you wear out the inside. Just corner hard....
Also, lots of tracks have trackside tire people. If you can get the fronts flipped inside out midway through the weekend, even better.
BTW, this is a prime reason to have a square setup. Ability to rotate tires almost pays for the cost of extra wheels.
Old Nov 1, 2012 | 02:49 PM
Andrew Wojteczko's Avatar
Don't be so sure it's too much until you test it.
Old Nov 1, 2012 | 03:06 PM
cracknut's Avatar
I switched to 225/45-17 R1s all around and thought -3.5deg in front was enough. Tire temps and wear pattern proved it was not.
Old Nov 1, 2012 | 06:33 PM
boyguan's Avatar
I feel that with even -3 the front wears the inside quickly
Old Nov 3, 2012 | 09:34 AM
Ludedude's Avatar
Administrator
Inside shoulder wear is more affected by toe than it is by camber.
Old Nov 3, 2012 | 09:40 AM
robrob's Avatar
It also depends on how much street driving the car will see. More street = more inside shoulder wear with high camber settings.
Old Nov 3, 2012 | 11:57 AM
crash's Avatar
I have been running 4.5 deg front camber for about 4 years.
I have looked at my car in pics and the tires are flat when in turns.
275x17's
mugen front bar
no rear bar
900F 925R spring
Old Nov 3, 2012 | 11:58 AM
Ludedude's Avatar
Administrator
True enough.
Old Nov 5, 2012 | 11:02 AM
GT Motoring's Avatar
Former Sponsor
Howd it go?
