Track alignments
Old Oct 17, 2012 | 10:56 AM
Biohazard's Avatar
Default Track alignments
looking for some alignment help for my track car. 08 CR
Current set up:
Stock CR suspension with the following:
17 x 8.5 +59 squared wheels
245/40/17 star specs
spoon x brace
S2 J's balls up front can adjust up to -4 to -5
Current alignment:
front -2.5 0 toe
rear -1.8 .28 total toe in
it has been pretty nuetral so far, but the rear gets a bit loose still in the corners, does anyone think I should run a bit more negative camber in the rear? say even it out to -2.5 front and back or even -3.0 front and rear? The car is stable at high speeds so I think the total toe in is o.k.
Appreciate the input, I run at mostly Road Atlanta, Roebling Road, and Sebring
thanks for any help you can provide
Old Oct 17, 2012 | 11:13 AM
psychoazn's Avatar
Given that we both run CR suspension, CR aero, and 8.5" wheels, here's my alignment. Take it for what it's worth.
J's S2 and SPC camber joints are used. 255/40/17 RS3, so the toe measurement may be ever so slightly different.
Front
-3.5 camber
0 toe
~6.5 caster
Rear
-3.6 camber
5/32" total toe-in
Can someone convert the two toe measurements to be comparable please? I don't know the conversion formula..
Old Oct 17, 2012 | 11:52 AM
hatrickstu's Avatar
I would def. look into more camber in the back. I dont have a CR, but it run -2.5 all around, i cant remember the toe settings though
Old Oct 17, 2012 | 12:38 PM
Biohazard's Avatar
thanks for the information.
Old Oct 17, 2012 | 02:56 PM
robrob's Avatar
5/32" total toe = 5 divided by 32 = 0.156 inch
My AP1 likes 0.2 to 0.25 inch total toe-in. I've tried less toe-in twice and both times the rear end got "quirky."
Old Oct 17, 2012 | 02:58 PM
MMisencik157's Avatar
I thought tire diameter was somehow factored into the equation?
Old Oct 17, 2012 | 03:47 PM
robrob's Avatar
You're thinking of the conversion from inches to degrees which uses sine waves and unicorn rays. I try not to mess with toe in degrees.
Old Oct 17, 2012 | 04:04 PM
ndogg's Avatar
1 degree is about .44 inches. So .28 degrees is about an 1/8"
Old Oct 17, 2012 | 06:00 PM
Originally Posted by MMisencik157' timestamp='1350514728' post='22090504
[quote name='robrob' timestamp='1350514578' post='22090501']
[/quote]
Haha thats what I was thinking of! Unfortunately my alignment shop uses degrees so Im trying to figure out this witchcraft in order to get the equivalent of 1/16" total toe in in the rear. Running 255 R-S3s all around if anyone knows how to help me
Old Oct 17, 2012 | 06:02 PM
Is that with a 255/40/17 or another tire with a 25" diameter?
