Track alignments
Old Oct 18, 2012 | 03:02 PM
  #31
andrewhake's Avatar
The FC RX-7s actually had flexible rear toe bushings to allow the rear toe to dynamically adjust based on the load O_O. The idea was to help with better turn-in, but the results are what robrob is describing. Most people would replace the rear toe bushings to eliminate that "feature".
I am really interested in seeing these cars on stock CR springs/dampers with J's camber joints.
  #32
odb812's Avatar
Originally Posted by ndogg
I think only running -2 will be a lot worse for your tires than driving to the track with -3...
Old Oct 18, 2012 | 03:07 PM
  #33
odb812's Avatar
Come find me at a track day next season. I'm in a stock CR with square 255s and saner front bar right now. Between seasons I'm adding camber joints and going for more neg camber. BTW, I'll be at the blacktrax day at THill next month if you want a before impression, but you'll probably make better use of your time riding with one of the many talented S2000 drivers that will be there.
Old Oct 18, 2012 | 03:08 PM
  #34
andrewhake's Avatar
Great I will be there and I will check it out. But I will be driving my own car I have driven an AP2 with full CR suspension setup, OEM CR alignment, and OEM tire sizes.
Old Oct 18, 2012 | 03:18 PM
  #35
andrewhake's Avatar
Do you affectively lower the car when adding the camber joints? Or is that only the case with the RCAs?
Old Oct 18, 2012 | 04:34 PM
  #36
psychoazn's Avatar
Just the RCAs. RCA pushes the lower arm down, while the offset ball joints either push the bottom of the wheel "outward" or pull the top of the wheel in.
Old Oct 18, 2012 | 04:56 PM
  #37
andrewhake's Avatar
Ah of course! Thanks. So your CR is at stock ride height still correct?
Old Oct 18, 2012 | 04:57 PM
  #38
psychoazn's Avatar
Originally Posted by psychoazn' timestamp='1350606898' post='22093607
[quote name='andrewhake' timestamp='1350602326' post='22093457']
[/quote]
Correct!
Old Oct 18, 2012 | 07:53 PM
  #39
robrob's Avatar
You'll definitely need an alignment after you add camber joints. You'll have lots of toe-out if you add SPCs on the upper a-arm or lots of toe-in if you add the lower a-arm camber ball joints.
Old Oct 19, 2012 | 08:05 AM
  #40
TougeHorseman's Avatar
Originally Posted by odb812' timestamp='1350601647' post='22093424
[quote name='andrewhake' timestamp='1350601335' post='22093409']
[/quote]
Oh, that crazy guy that lets everyone drive his s2000?
02_s2k
Apr 22, 2013 03:48 AM
psychoazn
Aug 24, 2011 03:58 PM
ECAhatch
Apr 30, 2010 06:49 PM
mr 280z
15
Nov 22, 2009 08:00 PM
Roadie
Oct 16, 2008 08:41 PM
