Changing pad compound + resurface rotor
Hello,
Anyone know if I wanted to try a different brand/pad compound that resurfacing the rotor would be sufficient enough to avoid cross contamination?
I'll still need to check if the rotors are past thickness spec.
That is more than enough. But why make the rotors thinner. Usually when I switch the pads I use sanding pad on the drill on both side. After that spray with brake cleaner. This are the racing pads right.
If you're doing it right. those rotors will crack LONG before they get too thin or reach their service limit.
If your new pads are even more aggressive than the old ones, you'd likely be fine doing nothing.
For around $50 you could have some brand new Centric blanks from RockAuto delivered to your house.
I may be in the minority, but I've learned that if you are driving the car to/from the track it doesn't appear to be necessary to even scuff/sand rotors when switching pads, including between brands of track pads. Most track pads are so abrasive when cold that they will do the job of cleaning off the old pad's transfer layer on your drive to the track. Similarly, they will clean off their own transfer layer on the drive back, so you can safely switch back to stock pads when you get home, if you bother doing that switch. I don't drive enough street miles between events to make switching pads worth it, so I just leave the track pads on all the time, and when they are toast, I just throw on the next set, regardless of brand, and head back out to the track.
Ok, great information here!
Freq, big fan of Centric rotors from Rock Auto! Thomas, I was running the same pad on and off track. They just dust like crazy as a daily use pad, hence having a pad/rotor for street only and another for track.
The old rotors, I'll just measure the thickness left and decide if I need one ones. If not, probably just pop in the old rotors with new pad compound and call it a day.
I have NEVER done anything beyond swap pads on my s2000 racecar. I have gone from hawk (dtc60) to carbotech (xp8-12) and all I do is throw the pads in and go run them. I can't see how scuffing the surface of the rotor does much of anything for track use.
Now, if you swap the track pads on AT the track and go right out and do a hot lap that would obviously be another thing entirely.
ghostsnake
04-27-2012 09:48 PM
tk416
11-18-2009 08:25 AM
