Tracking with OEM hardtop mounts
Old Apr 18, 2018 | 11:12 PM
Frenzy757's Avatar
Default Tracking with OEM hardtop mounts
Couldn't find anything on the search. I'd like to swap out my more permanent hardtop mounts with the OEM hardtop strikers/latches. Has anyone tracked with these? Any concerns/recommendations?
Old Apr 19, 2018 | 02:49 AM
imstimpy's Avatar
Been doing it since I bought the CR in 2014. The chassis flexes and loosens the OEM mounts slightly to create a bit of a squeek/rattle. Beyond that they appear fine. That said, I'm probably going to go for a permanent mount. If they are required for SM they probably have a good reason.
Old Apr 19, 2018 | 07:40 AM
Driven's Avatar
Yes. Ran mine with OEM hardware for years without any issue. The bolt in options squeak far more than the OEM hardware, so be prepared for a ton of rattles/squeaks... partly due to the terrible seals people use for the non-OEM tops, and partly due to the mounting hardware
Old Apr 19, 2018 | 10:14 AM
eight's Avatar
The OEM hard top with OEM mounts has been on my car since 2008. With tracking and regular driving, it's been fine. I've driven other's with OEM everything and without tracking and they have the same annoying squeaks and rattles that I have.
Old Apr 19, 2018 | 10:35 AM
freq's Avatar
Get some Ballade or PLMs.
I added some Ballade mounts with the no soft top option as part of my Winter weight savings project.
Old Apr 22, 2018 | 10:58 AM
Frenzy757's Avatar
Similar question I had in another subforum...
https://www.s2ki.com/forums/s2000-bo.../#post24449510
Anyone know if I can run the hard brackets with a soft top up?
BzNz
Apr 10, 2012 04:16 PM
vp special k
NES2KO Marketplace
Jul 28, 2010 02:16 PM
