UOA without baffle vs with baffle
Over the winter I installed a Ballad baffle plate and sent my first sample off to get tested. I figured everyone would be interested in the results, at least based on the first result the installation of the baffle plate seems to be a good thing! My guess is that the increase in silicon is due to the installation of the pan and possibly some extra Hondabond
Thanks for posting that is great info, and yes Hondabond will increase silicon content, the labs can't distinguish between dirt silicon or chemical silicon. The only other thing would be an air intake leak but not likely as you would have likely found it. Thanks for the info.
Mainly the lead. The aluminum is a bit higher but my guess is that was from the pan itself being a freshly machined piece of aluminum.
So is the thinking that there is occasional brief oil starvation (or at least some drop in pressure) that occasionally happens without a baffled oil pan which causes small but incremental wear of the bearings? And the baffling reduces this so hence there is less lead in the oil?
Yes, again this is just one sample, but the only change was the baffle. My lead wasn't super high before, but it was elevated. Admittedly it was trending downwards. So who really knows. One thing I do know is that the one sample on there had high lead, aluminum, and shearing. It was right after one of that hardest tracks on a car IMO.
s2konroids
Aug 26, 2013 04:15 AM
Reapur
Jan 10, 2013 10:07 AM
david.mt
Jun 25, 2011 12:01 AM
