Using reverse
Old Jun 18, 2017 | 07:39 AM
usafstud's Avatar
Default Losing reverse
Hi,
I have lost reverse gear on my last two track days. After I get done with my forst session, I can't push the shifter down to get into reverse. When I'm done wih the track day and given the car 1-2 hr to cool, I can push the shifter down. It is just a problem to park in the paddock sometime.
Clutch and tranny fluid are fresh. I used ATE for clutch.
any advice/thoughts?
Old Jun 18, 2017 | 03:16 PM
bgoetz's Avatar
I am interested in what you find out, I have been having difficulties in 1st and reverse, it seems very intermittent.
Old Jun 21, 2017 | 02:29 PM
usafstud's Avatar
anyone else with inputs?
BTW: title should be "losing" reverse
Old Jun 27, 2017 | 07:12 PM
devildust's Avatar
Default Same issue
I have the same issue between sessions on track. I put clutch in and reverse will grind going in as if clutch not in all the way. Not other gear does that, I have no issues with 1 or 2 in the paddock, but when it's time for reverse forget about it. Clutch fluid less than 1000 miles.
klemen123
Mar 9, 2015 09:20 AM
fadiss2k
Apr 25, 2009 04:51 AM
hondalegend
Sep 9, 2006 12:05 PM
jin6
Oct 13, 2005 06:31 AM
The Unabageler
Nov 18, 2002 01:42 PM
