Using WG with blower to fit HP class?
Old Feb 23, 2014 | 03:00 AM
josserman's Avatar
Ajax thanks for the help and breaking ground. For reference I took your final dyno and compared it with a random supercharged dyno with the same HP and the results are staggering!!
Standard build
With WG
Old Feb 23, 2014 | 03:19 AM
RAIN H8R's Avatar
That is a good read. However as i stated above I would mount the wastgate on the aftercooler right before the core. An intereting way to do it would be to mount a tial bov closest to the sc outlet. Then have a pipe welded on that extends the wg a measurable distance away from the aftercooler to make room to mount the wg. This way you never heat soak the aftercooler with air you will not even use.
I beleive no matter what you will flat line on power. However you could use that tour advantage to fix in a specific class.
Sent from my Samsung Galaxy S4
Old Feb 23, 2014 | 04:10 AM
josserman's Avatar
I know they are planning to mount it right before the heat exchanger! I like the idea of moving it away from the core and will talk to them about it!
Old Feb 23, 2014 | 04:11 AM
josserman's Avatar
By the way the power line under 6000 is really close with my old turbo setup at 450whp
Old Feb 23, 2014 | 06:47 AM
RAIN H8R's Avatar
Show me some graphs if you can.
Old Feb 23, 2014 | 06:51 AM
josserman's Avatar
Old Feb 23, 2014 | 10:25 AM
RAIN H8R's Avatar
Is that new sc setup vs old turbo setup graph?
Old Feb 23, 2014 | 11:58 AM
josserman's Avatar
No it's Ajax supercharger with wg vs normal supercharger vs my old turbo
Old Feb 23, 2014 | 12:37 PM
RAIN H8R's Avatar
I dont understand. You just listed 3 different cars. I only see rwo setups overlaying each other on the graph
Old Feb 23, 2014 | 12:59 PM
josserman's Avatar
No look at dynos above
