Using WG with blower to fit HP class?
Old Feb 27, 2014 | 04:38 AM
  #31
RAIN H8R's Avatar
Huh? Are you running the stock bosch diverter (aka bov)? I swear i can see it in the picture. To the right of the wastegate.
Sent from my Samsung Galaxy S4
Old Feb 27, 2014 | 05:10 AM
  #32
josserman's Avatar
My bad your right ! Wg and bov
Old Feb 27, 2014 | 05:47 AM
  #33
RAIN H8R's Avatar
Did you simply relocate the bosch diverter onto the air pump hole in the aftercoooler? Or did you weld on a 1inch pipe to attach tbe diverter to?
My concern is compressor surge at wot shifting
Old Feb 27, 2014 | 06:13 AM
  #34
josserman's Avatar
I didn't do any of the work but I'll ask the guy that did it was done by minitoyota and jeff evans by the way... Evans used a similar setup on a road course civic many yrs ago..
Old Feb 27, 2014 | 06:17 AM
  #35
99SH's Avatar
WG before aftercooler, the way it should be done
Looks nice! do you have radiator fans already mounted?
Old Feb 27, 2014 | 08:15 AM
  #36
RAIN H8R's Avatar
Please do. Sos provides a nipple that is smaller than 1 inch for the factory air pump. My concern is that they simply relocated the valve to that nipple, rather tban cut it out and weld on the proper size.
And again, i recommend running larger than the 1 inch valve. However, seeing as how you are bleeding off all the air that would normally net 18ish psi, you might be fine with the stock diverter.
Old Feb 27, 2014 | 08:43 AM
  #37
minitoyota's Avatar
Fans are installed in the above pics. There is just enough clearance from the wg to fans in that location.
The air pump nipple was cut off, enlarged the hole and we welded a 1" pipe on.
Old Feb 27, 2014 | 09:57 AM
  #38
yamahaSHO's Avatar
Anyone consider using a restrictor to limit top end power?
Old Feb 27, 2014 | 04:13 PM
  #39
donaldmejr's Avatar
Looks a lot like mine
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old Feb 27, 2014 | 05:14 PM
  #40
josserman's Avatar
Wow awesome - how has the setup worked for you?
So first dyno today on 93, E85 tomorrow. Really impressive powerband and tq for only 340hp on this setup
