V710 Tire pressures
I'm a diehard Hoosier man that is switching to 245/265 Kumho V710s for autocross. I'll be running all aspalt courses this year. What are the typical pressures that you guys run? I've heard 30lbs rear, 32 lbs front from one competitor.
This is for A Stock on AP1 rims. I have the Gendron bar, full stiff, Konis, and a typical autocross alignment.
Thanks
Thanks
Running 30psi all around last year gave me moderate understeer with my Comptech on full stiff. More pressure in the front might have helped as well as backing the bar off slightly. I tried neither...
Check them after your first run I found mine went up quicker than my street tires even on a cold day.
I went from 35psi to 41 after 1 run
I dropped them down to 35 and the car felt fine I will try lower next week.
