Weld in Roll bar or bolt it in?
Old Sep 10, 2012 | 10:44 AM
S2000_916's Avatar
Default Weld in Roll bar or bolt it in?
I notice most guys bolt in their Hard Dog or Rockstar roll bar, but wouldn't a welded one be better?
Old Sep 10, 2012 | 04:44 PM
postman's Avatar
depends on your needs/goals. unless you plan on making this a career race car, bolting it in is probably just fine. once its welded removing it would be a major pita.
Old Sep 10, 2012 | 06:35 PM
robrob's Avatar
Welding it in place is a pain in the butt too. You have to remove all the sealant and paint completely for weld prep and you'd end up with it welded to mostly thin sheet metal. The 4 backing plates and 16 bolts work very well in anchoring a roll bar in the S2000. It's very easy to remove a Hard Dog bar if you simply leave the forward backing plates in place (makes re-installation easy). Hard Dog will sell you a new set of forward backing plates.
I've never heard of anyone using a Hard Dog type roll bar as a base for a full roll cage. We unbolt them and sell them for almost what we paid for them and have the cage built from scratch.
Old Sep 18, 2012 | 09:30 AM
LandR's Avatar
welded mine in - was very simple and easy and also did not involve cutting up the underbody of the car.
I have a spare set of backing plates if anyone wants.
Old Sep 21, 2012 | 07:00 PM
starrman's Avatar
Bolted mine in...would weld it if I ever did it again...either way it is a pita.
robertbrite
Nov 14, 2018 09:36 PM
Lttakas
Aug 1, 2013 05:07 PM
