What alignment settings should I use?
Hi,
After doing 5 autocrosses with a MY00 AP1 S2000 that I got in late March 2011, I am finally doing a couple of upgrades. I think I have reached the limit of the tires that are on the car (300 f/ 400 rear treadwear)
I'm puttin going on some Dunlop Star Specs on my AP1 wheels but I'm going to install a set of SPC camber joint to help with the camber setting on the front.
What alignment setting should I get for AutoCrossing and for HPDE events?
I saw that the FAQ on autoXing but the alignment setting seems kind of mild.
•Front toe - 0" to 1/8" toe out
•Front camber - maximum available (generally between -1.5 to -1.8 degrees)
•Rear toe - 1/16" to 1/4" toe in
•Rear camber - -0.2 to -0.5 degrees more than the front camber
The S2000 is not my DD so I only expect to get about 7K miles out of a set of tires. The car is bone stock. I'll be installing brake pads, lines, and brake air ducts when I have the wheels off for the SPC install.
I'm in for this thread just to get ideas for a good baseline alignment.
I'm running stock coilovers, Saner front bar, 17x9+63 TSWs with 255/40 RS-3s F&R.
Did all that and didn't get an alignment...
But I wanted to find what a good baseline would be before I forked out the cash to get it done.
