What AutoX Class am I in?
I just did my first autocross yesterday and when I arrived they put my in the rookie/novice class but asked what class I should be running? I really have no idea, Can you guys let me know where to look?
2006 S2K. K&N FIPK, Invidia exhaust and TP, Hondata reflash. Aftermarket wheels and tires but OE AP2 size. Stock suspension but with a upper strut bar.
Thank you!
Thank you!
Originally Posted by TheLast13,Sep 7 2009, 05:58 PM
Is the ECU reflash hurting me as well?
as far as s2k's go BSP allows you to go much wider with wheels and tires and lets you use R-comps... It also allows you to delete emissions and a few other things... STR is 9in wide max wheels, 255 wide tires max, need emission control, only street tires allowed and a few other small differences....
as far as competition, in BSP you will be agains evos and STIs with boost cranked up on huge R-comps and generally be outclassed even if you built your car to the limit... in STR you will be against 350Zs, BMW Z3/4, Miatas, Pontiac Solstice and a few others with similar tires to you and similar mods and will be fairly competitive at least locally.
