What breaks in competition?
Old Oct 23, 2006 | 05:55 AM
FF2Skip's Avatar
Originally Posted by Slows2k,Oct 22 2006, 11:30 PM
Skip, That sounds like pitted inner CV joints to me.
Swapping half-shafts side-to-side wouldn't temporarily cure it, would it? I believe I remember reading about folks doing that.
Old Oct 23, 2006 | 06:12 PM
Windscreen's Avatar
You can't swap halfshafts side to side because they are different lengths. You can, however, swap the inner CV side to side to cure the acceleration vibration problem. It's a little more involved, but if you can pull out a halfshaft, you can pull apart a CV joint.
This fixes the problem for quite a while because you are reversing the drive and coast sides of the CV joint. Once upon a time there was a thread with really good pics of the inside of the joint and the pitted or brinelled surface that caused the vibration. Too bad about the search function.
Steve
Old Oct 23, 2006 | 07:12 PM
Slows2k's Avatar
Old Oct 23, 2006 | 08:53 PM
rlaifatt's Avatar
https://www.s2ki.com/forums/index.ph...ic=241367&st=0
Old Oct 25, 2006 | 02:43 PM
FF2Skip's Avatar
Thanks, Richard. I actually found that on my own after perusing through the FAQ's. Doing it tomorrow.
Old Oct 25, 2006 | 04:00 PM
SC_Highlander's Avatar
I swapped inner cv 'cups' right-to-left last spring, as I was just starting to get a vibration on the highway. It fixed that problem right up.
Old Oct 25, 2006 | 04:11 PM
FF2Skip's Avatar
Bryan, what time will you be here tomorrow?
Old Oct 25, 2006 | 04:48 PM
Can't do it tomorrow.
Old Oct 25, 2006 | 06:37 PM
SteveS2K33's Avatar
Motor mounts. My car has 95,000 miles on it and I broke both of them at a Evo School a couple of months ago so they are something that should be changed if your car has higher miles just for a precaution. I sam a pic somwhere on here where a guy ripped the mount out of the block, that wasn't good.
Old Oct 26, 2006 | 08:52 AM
twohoos's Avatar
Also see recent thread:
https://www.s2ki.com/forums/index.php?showtopic=429413
mk84
Jun 6, 2016 05:49 AM
chris-stockton
Nov 21, 2014 10:43 AM
TwinTurbo540
Apr 23, 2013 11:33 AM
dollag2k6
Jun 30, 2012 11:43 AM
S-Turn AP1
Jul 27, 2008 10:17 AM
