what catch can do you use
Old Mar 1, 2010 | 12:15 PM
SC_Highlander's Avatar
I blocked off #2 and #4. I used a 1.5 qt summit racing breather bottle with an air filter on top. It came with one input and I added another by buying a 'replacement fitting' kit and cutting a second hole. #1 and #3 are connected to this can. It is mounted to a bracket on the front crossbeam.
Old Mar 1, 2010 | 12:41 PM
josh7owens's Avatar
is this the ideal set up?
Old Mar 1, 2010 | 01:29 PM
SILAP1's Avatar
kinda
Old Mar 3, 2010 | 10:02 AM
pgss2k's Avatar
From an old search I read about "Krank Vents" Are these also still a viable alternative?
Old Mar 3, 2010 | 12:23 PM
dan_uk's Avatar
I bought an ebay 1/2l $15 one and stuck it next to my Deka battery
I think I only connected it between 3-4, I didn't know 1-2 could cause smoke
I only realy got blowby/smoke in Roebling T4 and it stops it for me except it can fill the catchcan in one session sometimes
Old Mar 3, 2010 | 02:53 PM
albertg's Avatar
dan_uk, can you snap a quick pic of your setup. I too have one from ebay but not sure where to mount the can itself.
Old Mar 3, 2010 | 04:43 PM
dan_uk's Avatar
[QUOTE=albertg,Mar 3 2010, 03:53 PM] dan_uk,
Old Mar 3, 2010 | 04:54 PM
albertg's Avatar
^^Thanks! Thats what I figured. That was where I was going to try and fit it. I think I can still get the can in there with my regular sized battery, but below the ac line, using the tie down as the mounting point.
Old May 5, 2010 | 12:18 PM
Hero's Avatar
should the lines be 9mm or 15mm? or does it matter much?
Old May 5, 2010 | 12:29 PM
Driven's Avatar
The one I use: $20
I laugh at people who spend $200+ on what could be done for $5 (used pepsi bottle and some rubber hoses).
Also, I run it where one line from the PVC goes to one side of the catch can, while the other side of the catch can goes back to the intake manifold.
this is on an otherwise stock motor (no K&N, no header, etc).
