Wheel bearings and hubs for track use
I have always been able to notice a difference when turning (i.e. loading it up) too. So when the driver side failed, going around a right turn you could hear it, and vice versa. In a straightline, noise was minimal.
Andrew. You will notice when they start to fail as they will make a whirling noise under load. Sounds like a really loud tire
I have 140k on my bearings and 80 on my other car. I wouldn't replace until i got some noise
At least Ill know exactly what it is and to replace it sooner next time.
Thanks. Yeah I believe I could be getting noise from my nicely worn rear rotors as well, which will be swapped tomorrow so I can take a closer look. Hopefully it's just that. My car does get airborne a few times a month though.
Originally Posted by Voodoo_S2K' timestamp='1383592193' post='22861301
This is more Honda specific vs S2000 specific, but most of the Honda Challenge guys I know that went the cheap route with non-OEM hubs and bearings suffered from much shorter life span compared to Honda OEM stuff.
It is interesting that your passenger side when out before the driver side.
I think its because I run CCW tracks/configurations much more than I do CW... Buttonwillow CW13 and Sonoma are the only tracks Ive run CW and Ive only driven CW13 three times and Sonoma once.
I like the Timkin bearings from Autozone. I've never had one fail or wear out (yet). Don't know anything about the hubs.
I do recommend for you serious track guys to install extended wheel lugs and open lug nuts when you replace the front bearings and/or hubs just so you're good for a future big brake kit with spacers.
Noble (08-29-2019)
