wheel studs stretching?
Old May 20, 2009 | 10:50 AM
  #21
copmagnet82's Avatar
What I usually do at the track, I just don't go out for the last session, wait a few minutes for things to cool down, then take my wheels off and wait for everything untill it's fairly cool to touch (30-60min) and then I put my stock wheels back on. It's quite annoying to do it that way, but better safe then sorry.
Old May 20, 2009 | 12:49 PM
  #22
SpitfireS's Avatar
TubeDriver Posted on May 20 2009, 06:56 PM
Using an antiseize or grease on the lugs will substantially increase the torque applied, I always use dry, clean lugs.
How?
I mean, when the wrench clicks at 110Nm, that IS the torque applied.
The torque wrench measures the force you, the operator, apply to it.
Force X arm length = torque.
The difference in using lubed or dry thread is that with dry threads more of the force is needed to overcome friction and with the total force being the same less remains to press the wheel against the hub.
If you have worked with stainless steel bolts and nuts you know to always use a thread lube compound, stainless steels bolts and nuts have a habit of welding together pretty easy.
And it is welding, at contact point the friction gets so high it develops enough heat to melt steel.
Wheel studs are steel, not stainless, but a bit of lube helps.
I do keep the ball shaped seat - on the nut and wheel - clean.
Just lube the threads.
Old May 21, 2009 | 07:45 AM
  #23
TubeDriver's Avatar
How?
Torque will remain the same but clamping force will almost double when antiseize is used which could/will eventually lead to nut/lug material failure.
Old May 22, 2009 | 05:36 PM
  #24
E_N's Avatar
E_N
That is the absolute opposite of true. A higher clamping load reduces the chance of a fatigue failure (provided you do not yield the fastener when tightening it).
Use anti-seize and a torque wrench, and everything will be alright.
Old May 22, 2009 | 06:26 PM
  #25
captain_pants's Avatar
[QUOTE=E_N,May 22 2009, 07:36 PM] That is the absolute opposite of true.
Twonius
Dec 25, 2015 02:26 PM
Syn
Mar 5, 2012 05:45 AM
jeallen
Sep 18, 2010 11:39 AM
mikecl713
Sep 23, 2004 11:33 PM
JohnDoe02
Nov 17, 2003 03:35 PM
