WOW! Is alignment critical!
Just wondering,
Why are the U.S. Specs different from the U.K. Specs?
I know they change the handling, but why would Honda want the car to handle differently in the two markets?
Willinathen
Willinathen
3312DC.......when is the next track event i could meet you at in our area?? I am finally ready to get it out now....and see what it can do.
The most important part about the UK spec is not the camber change its the rear toe in change.....it totally tames the oversteer problem the s has.....i think i may relax my front sway bar setting a knotch now.
S2000 Original Wheel Alignment
Camber
Front -0 deg 30 min
Rear -1 deg 30 min
Caster
Front 6.0 deg
Total Toe
Front 0 mm
Rear In 6 mm (1/4 inch)
UK TSB Wheel Alignment Recommendations
Honda UK settings are published in degree/minutes and some machines take inputs in decimal degree which is translated by = sign.
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Front 6 deg 45 min = 6.75̊
Total Toe
Front 0 mm
Total Toe 0 deg 40 min (0 deg 20 min per side) = +0.32̊ (+0.16̊ per side)
When introduced in Britain a number of British magazines complained about the S2000s handling characteristics. In 2001, Honda UK pounded S2000's round MIRA's test track for several days trying alternate settings. In Britain the spec
Camber
Front -0 deg 30 min
Rear -1 deg 30 min
Caster
Front 6.0 deg
Total Toe
Front 0 mm
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Total Toe
Front 0 mm
