XP10 front & rear
Old Jun 15, 2012 | 02:06 PM
BLkAP1's Avatar
Default XP10 front & rear
I ordered pads XP10 (front) & XP8 (rear) but a full set of XP10s showed up. Before I send the rears back, I just wanted to ask if anyone was running XP10s on both ends and if it was ok?
Thanks!
Old Jun 15, 2012 | 02:23 PM
06Estukay's Avatar
Provide more details of your car setup... Especially your tire sizes.
Old Jun 15, 2012 | 02:55 PM
BLkAP1's Avatar
Tires are Star Specs 225/245 and spring rates are 500F/400 (F/R).
Old Jun 15, 2012 | 04:55 PM
iLuveketchup's Avatar
I run XP10s F/R. It's fine.
Old Jun 15, 2012 | 05:41 PM
macr88's Avatar
Aero? If yes then you'll be fine.
No aero and trail braking will be fun
Old Jun 15, 2012 | 06:21 PM
BLkAP1's Avatar
Nope, no aero. How fun?
Old Jun 15, 2012 | 10:06 PM
FluKy15's Avatar
Curious to hear thoughts on this too, because I love me some trail braking.
Old Jun 16, 2012 | 05:42 AM
robrob's Avatar
XP10s seem to be very flexible pads as far as temperature goes and I did run them all around for a while and they worked fine. I did switch to XP8s in the rear though and got a slower wear rate with them. You probably will get ABS in the rear slightly before the front but it doesn't really affect stability that much. I'm a heavy trail braker and didn't notice much of a difference. If you're not in a hurry then swap them for 8s, if time is an issue then run them and it'll be fine.
Old Jun 16, 2012 | 07:02 AM
ZDan's Avatar
I've always run the same pads front/rear, my ABS doesn't work, and the fronts always lock up first, wet or dry, R-comps or winter tires.
That's with XP8/XP8 and with HP+/HP+.
Never any issues with trail-braking instability.
Old Jun 16, 2012 | 10:28 AM
BLkAP1's Avatar
Thanks for the input guys. It sounds like XP10 all around is not too bad so I might keep them.
If I choose to return the rears, I do have an extra set of HP+ rears I can run. Would that combo work ok? (XP10/HP+)
