IS350 vs s2k
Those things are pretty quick. It will most likely walk all over you if you are stock or have only basic bolt-ons. I was about to race on the other day but then it ended up not happening. But when we were going to the spot we race at, it seemed like it could beat me. However the IS250 is a completely different story.
Originally Posted by kumainu,Oct 14 2006, 02:30 PM
Mostlikely that IS350 will pull a good amount on stock S2000. The hp deficit is just too much. Handling-wise, it's a different story.
they run close to the same 1/4 and the s2k actually traps faster. i say from a dig you'd better be on your game or else he'll get past you. from a roll i'd say the s2k should be able to pull away.i've run a modded i/e is350 and i was able to say ahead, although it was faster than any 350z i've ran.
Here: http://www.caranddriver.com/comparisons/10...exus-is350.html (and that one was not broken-in yet).
Originally Posted by kumainu,Oct 14 2006, 03:49 PM
Uh, no! IS350 with a competent driver should be able to get 5.0 sec 0-60 and 13.6 @ 105 mph in 1/4mi. Usually, S2000 cannot touch that. Your modded S probably can, but not a stock one.
