S2000 Street Encounters Stories of on-the-road exploits and encounters.
View Poll Results: Launch RPM Poll
6000-6199
10.53%
6200-6499
5.26%
6500-6699
10.53%
6700-6999
13.16%
7000-7300
23.68%
Less than 6k
10.53%
I don't/never launch my stook
26.32%
Voters: 38. You may not vote on this poll
Launch RPM Poll
Old Aug 12, 2001 | 05:02 PM
amartin's Avatar
What RPM gives you the best launch, and why?
-- Aaron
Old Aug 12, 2001 | 07:39 PM
Sev's Avatar
Sev
-- Aaron
This is a completely useless poll as the launch RPM depends on:
1: Tire pressures
2: Tire wear
3: Outside temperature
4: Asphalt conditions and heat
5: Weight in car (example: baggage and passengers, spare or no spare, how much gas...)
All I can tell you is that you will get wheelspin, however if the RPMs decrease you are not high enough for those conditions, or you have to give more gas. The usual range for hot weather and stock tire pressures is 7k+. I highly reccomend putting the pressures up to about 38 psi cold, then you will need about 6-6.5k.
Old Aug 12, 2001 | 11:33 PM
amartin's Avatar
Fine.. 80 degrees F, 40 percent Humitity, Hot-tires... Dry roads, S02 Tires with 2000 miles on 'em... OR there abouts.
-- Aaron
Old Aug 15, 2001 | 10:06 AM
amartin's Avatar
Interesting results...
-- Aaron
SilverS2KAZ
Apr 16, 2004 04:09 PM
psyclone
Oct 12, 2003 03:51 PM
DSR88
May 24, 2002 02:43 PM
pHILZ421
Jan 14, 2002 05:55 PM
S2Krazy
Dec 13, 2001 05:12 PM
