S2 vs 300ZX TT
[QUOTE=sunrise089,Feb 27 2006, 11:38 AM] I'm 99% sure you're wrong anyway, but I'll try to remember and check back later in the day. This issue is really difficult though, because it's almost impossible to find a Z to test this on. The 300zx is governed from the factory to well below its drag limited top speed. Many TT z32s have the governor removed when they add an aftermarket ECU, normally as the third common mod done to a TT (intake+exhaust+ECU = 100hp gain at the flywheel). Unfortunately for our purposes the ECU also adjusts the engine's timing as well, resulting in a power gain, as well as the gain supplied by the included boost jets.
Raced a fairlady 300zx at the strips and we were dead even, it was TT and had i/e plus a bunch of other mods. Stock turbo with just add ons and bolt ons, I thought they were faster than that? Must be the driver, who knows... Oh and yes it's a manual...
Originally Posted by 95rtturbo,Feb 27 2006, 06:54 AM
300BHP in a 3400-3500 LBS car does not equal 172MPH (even with the limiter removed). M6 C5 Corvettes top out around 170-172 with ~50 more FWHP, less weight, better highway gearing, and better aerodynamics. I doubt my Stealth will hit that speed, and it is faster than my lightly modded 300ZX. Again, no way.
http://videos.streetfire.net/search/corvet...ACD4F173C86.htm
A M12 equipped C5(Z06) has a lower top speed of 179mph I believe. They are both aerodynamically limited. With enough power, the stock 6th gear can go well above 200mph.
Originally Posted by nevert00fast,Feb 27 2006, 12:41 PM
Actually a MN6 equipped C5 is capable of a higher top speed.
http://www.conceptcarz.com/vehicle/z251/default.aspx
plus they stopped making them in 95 or so, so even the newest ones are 11 years old.
-Chris
170mph can be done if ECU and engine mods are added to include turbo upgrades and better fuel delivery. As far as factory internals and just an ECU upgrade, I'm not sure.
I will say this.
The VG30DETT is a great engine to make power with and it is common place to see one pushing 400whp with no work on the block itself i.e.
rods, piston, and so on.
One of my favorite cars ever!
I will say this.
I will say this.
I will say this.
By the way, does anyone in the Saint Louis area with an S2K want to do some friendly runs (with my mostly stock Z)? Should be a close race.
[QUOTE=95rtturbo,Feb 28 2006, 06:11 AM] Yes, 170MPH can most definitely be done with minimal modifications (ECU, exhaust, downpipe, intake, etc), because the ECU includes boost jets that raise the boost, increasing the power output of the engine.
