SL500. Fast or not?
Got a friend who just bought an SL500 2 days ago and is bragging about it. Saying it's got +300 HP and will kill my Z4 3.0 SMG, laughing at the Z4's 225 HP. He wants to race me for $100.
His SL500 is stock. I checked his engine bay.
My Z4's got intake, exhaust. Good for about extra 10~12HP I think.
I don't know much about SL's. How's my chances of winning? Thanks!
The SL has 300hp, period. Not over 300 like he's stating. It's a very heavy car and does the 0-60 in about 6 seconds. If you shift just right, you could maybe take him on.
Now if it was an AMG on the other hand, you should steer well clear...
5.0L 24-valve V-8 engine
302 hp @ 5,600 rpm
339 lb-ft @ 2,700 - 4,250 rpm
0-60 mph in 6.1 seconds
Coefficient of drag 0.29 (top up)
Curb weight 4,065 lb/1,844 kg
MSRP: $92,020.00
http://www.mbusa.com/brand/container.jsp?/...spec=0&menu=3_0
BMW Z4 3.0 SMG
Weight
Unladen 3020 lbs
Engine
Liter/type/valves 3.0/DOHC inline 6/24
Nominal output/rpm 225/5900 hp
Max. torque/rpm 214/3500 lb-ft
Performance
Drag coefficient 0.35 Cd
Acceleration 5.9 sec
MSRP $41,300
http://www.bmwusa.com/vehicles/Z4/30i/techdata.htm
A quick look shows that they have actually pumped up HP since it's outing. The SL 500 used to be 300hp (european ponies), now it's 306 (so that's about 302ponies as calculated by the americans).
It was the same with the SL55. It used to be only 470hp or something like that, but a few months after it's release, AMG bumped it up to 500.
Wow. SL500 takes 6 seconds to go from 0-60mph? That's a lot slower than I thought it'd be.
I'd assume that MB under-rates the 0-60 time, just like BMW does. I know Z4 consistently runs 5.4~5.5 during magazine test-drives, about the same as S2000. I'm going to race my friend tonight and I'll see what happens.
BTW, is MB still selling the SL500? I'm guessing not since the new SLK 350 is even faster than the SL500. I test-drove SLK350 and actually like it quite much. SL500's resale value must be going down the drain after the SLK350 came out.
I raced one twice with my stock 97 Z/28. My car should be a good measuring stick since it does relatively the same times as a stock S2K should.
I launched a lot harder off the line since the driver did not know how to brake torque it. At 100 mph, I was about 3.5-4.5 car lengths ahead, which sounds about right to me.
Seeings how Z4's are a tick or two behind S2k's, I think you will do fine....it will come down to the launch. The SL is a heavy ass mofo!
