S2000 Street Encounters Stories of on-the-road exploits and encounters.
Z06 vs KW Highboost
Old Nov 13, 2009 | 11:44 PM
GrandMasterKhan's Avatar
Default Z06 vs KW Highboost
Over the summer I randomly met up with a guy with an 04 Z06. He had a few bolt ons and was putting down 386whp. We did a few runs and the result was him pulling on me by about 2 cars.
Well, hes back in town and we both have a few upgrades since then and have been itching for a rematch.
I installed 4.57 gears and a Berk High flow cat. He did a retune and added a Borla Exhaust resulting in 408whp.
We decide to do a highway roll and on the third honk we both punch it. I can hear is exhaust scream its v8 roar and my S/C is soaring through the wind. We are NECK and NECK with him gaining only an inch every second or two. It was truly a viciously close race. 60-110
I am thrilled it was such a close race. I thought i'd share with you guys! Enjoy!
04 Z06: TB & intake, long tube headers, tune, borla exhaust 408whp
06 Kraftwerks S/C 10psi: 355whp, berk high flow cat, stock header, stock exhaust, 4.57 gears.
Old Nov 14, 2009 | 03:22 AM
Abdizzle's Avatar
350/400WHP cars going at it for 1 gear/40MPH.
Too bad there are no half mile drag strips because otherwise races like these are a bit pointless.
Old Nov 14, 2009 | 08:28 AM
I started at 7000 in 3rd which is 62. So I need to edit that
Old Nov 14, 2009 | 12:02 PM
g35s2000's Avatar
Banned
good run! do u think having a high flowing exhaust and header would've made a difference? and im assuming ur using gears to take advantage of the centrifugal nature of building boost by rpm.
Old Nov 14, 2009 | 02:15 PM
I am sure if i opened up the header and exhaust with a proper setup then i'd gain some power. The gears made a pretty nice difference and helped close the gap between our cars despite his recent power adders.
Old Nov 14, 2009 | 02:24 PM
1999's Avatar
how much torque with your set up?
Old Nov 14, 2009 | 02:47 PM
264wtq
Old Nov 17, 2009 | 09:36 AM
Q8s2k's Avatar
Sounds like Fun!
Adding a 70mm Single Cat-back would have definitely won you the race, it should net you atleast 10-15whp and 40lbs weight reduction..
Old Nov 17, 2009 | 12:18 PM
unethikl's Avatar
good run! awfully slow c5z06 tho
Old Nov 17, 2009 | 12:45 PM
Crackerballer's Avatar
GMasterK, what are you tuned on?
