0-60 ?
btw, i dont think that stuipd site has its shit right either, it says 00 does 13.9 i believe iwht a 5.2 but the 03 does a 14.9 wiht a 6.2...sorry but BULL SHIT n from what i know, the 02-03 is the fastest model due to teh ecu change.
Originally Posted by B SweepeR B6,Apr 18 2005, 12:29 AM
can you give me some details on this? i have kinda hit rev limiter in 2nd gear for some stupid
ing reason this past week or so a lot on the freeway. Something i dont usually have occuring, is that going to affect nething? n i have downshifted quickly into a lower gear n going WOT, will that affect anything? affect the motor mounts? differential? anything at all? thanks.
Yes, the webiste is fishy, but so is every other source out there. I think WisconsinS2k has proven to this guy that magazine racing is pure
. That should be enough
Originally Posted by Wisconsin S2k,Apr 17 2005, 09:16 PM
(the car in stock form is drag limited to about 163, so without a few more horsepower or going down a slight hill, you wont get more than that)
Originally Posted by 2cents,Apr 18 2005, 09:14 AM
range is 5.2 - 6.3.
5.2 + 5.5 + 6.3 / 3 = 5.67
median is 5.5.
mean is 5.7.
so if you're
a believer you will run 5.2,
a skeptic: 6.3,
and all the rest will run 5.7.
median is 5.5.
mean is 5.7.
so if you're
a skeptic: 6.3,
That was clever!
Originally Posted by Caffeinated21,Apr 18 2005, 09:20 AM
Am i the only one who thinks that's BS. I have personally taken an stock S2000 up to the top end. It hit 147 and wouldn't go a mph faster. Admittedly it was a cold night so there was more drag, but i have a hard time beleiving that environmental conditions (short of a tail wind and a downhill) could acheive 163. 155, but not 163.
There is no set method for calibrating times by magazines.
They've used everything. Acelerometers, laser, radar, 5th wheel, timing lights... and most recently GPS.
Motortrend Quote:
First, some clarification on test methodology and interpretation of the data and results. The friendly folks at Racepak Competition Systems (949/709-5555) agreed to demonstrate their latest data-acquisition equipment that utilizes GPS technology to chart location, course, and velocity of a vehicle, sometimes called telemetry. Once this information is determined, the possibilities for total track mapping are nearly infinite: lap times, segment times, entry/exit speeds, minimum/maximum speeds, average speed for a lap or any portion thereof, plus g-loads in every direction at any point on the track. A GPS antenna the size of a matchbook, combined with a 15-ounce, paperback-size module literally replaces at least four radar guns, two accelerometers, and a handful of timing lights. The sampling rate is constant at 20 times per second, so, depending on the velocity of the subject, the resolution of the data can measure mere inches at slow speeds to about seven feet at 100 mph. We used this system to determine both top speed and all the data for the Figure Eight test.
Motortrend Quote:
