04 vs 03 Dyno test on vtec.net
Old Nov 10, 2003 | 03:26 AM
  #101
Barry in Wyoming's Avatar
Originally posted by ultimate lurker
Sorry Barry - substitute "accelerates" for "is"
UL
That does make sense.
I loved your article on www.vtec.net and can't wait for the handling part.'
There's nothing like real data for evaluating a difference.
The second piece is the part you alluded to, running the two S2000s against each other.
Old Nov 10, 2003 | 03:27 AM
  #102
RedMenace's Avatar
I wonder what the ambient air temperature was during this dyno comparison??
Those of us with pre-2004 S2000's know that the engine management becomes very conservative as the air temperature goes up. With the significantly lower redline the MY 2004 might get away with much different mapping.
On warm days in traffic my MY 2001 loses a lot of power; be interesting to see if MY 2004's show the same behavior.
Old Nov 10, 2003 | 03:39 AM
  #103
mav's Avatar
mav
Undoubtly the new MY04 should and will make more HP and torque but by 26HP more? Thats what I have a hard time believing...
Old Nov 10, 2003 | 05:20 AM
  #104
steve c's Avatar
quote]If you want to talk about advance, name me a 30K ferrari that can match up to us. They can't, because 30K will buy just a front and rear bumper w/o paint.
Why would Ferrari build a 30 thousand dollar car, and why are you comparing your 30 thousand dollar Honda to a Ferrari?
Scientific data: Honda retains the highest resale value for a few reasons. RELIABILITY
You named only one reason, not a few, and even at that Honda does not have the highest resale in all categories, or off the top of my head any for that matter. Moreover, what does resale have to do with technology or Ferrari?
My data, which includes some 50-60 S2000s
Ah, well you did not state that earlier.
As what I've always expected, the 04 will dyno more than any previous model even though Honda still rates its hp the same at the crank. No matter what type of dyno you put it on, MY04 will put out more power than any previous model. My instincts are always right.
While I realize that statement is probably tongue in cheek, you know someone will take that as fact and not speculation.
Old Nov 10, 2003 | 06:22 AM
  #105
B.C.'s Avatar
[QUOTE]Originally posted by Hyper-X
I look at published numbers as a reference to go by, not as the absolute performance level.
Automakers can claim any HP figure since there's no law mandating a 3rd party to check out their claims.
Old Nov 10, 2003 | 06:24 AM
  #106
smyroad's Avatar
I'd expect a HP bump since the displacement was bumped. The Dyno day we had a currey's a couple of years ago produced a 10 HP range between between all the stock S2000's that ran that day. I wonder if the dyno guy accounted for the new gearing in the tests.
Old Nov 10, 2003 | 06:40 AM
  #107
Big Ben's Avatar
Jesus christ. When will this end?
The '04 S2000 makes more power and torque than the '01 to '03 S2000. The power is more usable also. End of story. Get over it already.
Old Nov 10, 2003 | 06:53 AM
  #108
steve c's Avatar
Wrong. One 04 made more horsepower than one 03.
It's a damn good thing I did not stay in the scientific field.
Old Nov 10, 2003 | 07:02 AM
  #109
ttb's Avatar
ttb
[QUOTE]Originally posted by 'smyroad
Old Nov 10, 2003 | 07:06 AM
  #110
ultimate lurker's Avatar
Accuracy, in the case of a chassis dyno trying to ascertain engine numbers, is not very meaningful. What is important is repeatability and consistency (precision officially). The Dynapack is guaranteed by its manufacturers to be repeatable to +/- 0.3%. In repeated tests that I've done on the same car (for an oil company), I usually see standard deviations in the data that amount to about 0.5% of the mean. Given that I can't control environmental conditions absolutely (or measure everything I want to on the car to ensure complete consistency), I think Dynapack's claims are appropriate.
The sample pool of stock pre-04's must be divided into the 00-01 and 02-03 groups as they are distinctly different. In terms of output, their ranges just barely overlap. IOW, the best 00-01 (stock) that I've tested made about as much power as the worst 02-03 that I've tested. I never bothered to run a full analysis (I only do that when I get paid as I have to export the data and run it through some excel files), but as I said, the average for the late models is 5 hp higher than the early models. And given that the extremes of the two sample groups don't overlap you can make a rough estimate of StdDev (it'll be about 1 to 2). That could put the average of the 00-01 group just within 3 StdDev of the average for the 02-03 group, but it also means that a substantial number of the 00-01 group would fall outside the range. You could combine the two groups together, but as I said, there are distinct changes between the model years, including an ECU part number change and datalogged timing changes that make this unwise.
The TCF factor is a user entered factor to provide an estimate of flywheel hp. There is no mystery, especially as it is placed in direct view for everyone to see so that results can not be improperly manipulated.
smyroad, gearing changes were accounted for, although that would _not_ change the hp numbers, only the torque numbers and calculated rpm. In your dyno day, was everyone running the same wheels/tires, with the same tread depth and inflation pressure and was each test made at the same intake temp (differential relative to ambient) and coolant temp? If not, you've introduced some significant variables into the measured output of the vehicles.
UL
Originally posted by SECRET AP1
Out of a pool of 50-60 pre04 S2000 dynos, you should be able to calculate the uncertainty (say 95% confidence interval) about the true mean value of your data. As far as I can recall, 50 measurements is enough to consider a z-distribution. It will definately help you check the quality of the measurements your taking. The standard deviation (or a rough estimate of +/- 5HP) isn't quite sufficient in proving that your data (or the instrument, in this case the dyno) is acceptably accurate and precise.
I don't doubt your ability as a tuner or your knowledge; it is the Dynapack that I do not have faith in. The TCF, as you said, seems like unnecessary factor that only adds to the mystery of Dynapack dynos.
Anyways, a couple quick calculations and the uncertainty will tell you alot about your dynamometer.
