1/4 mile with 4.77
Actually, what's wrong with shifting at more than 9000rpm? My car doesn't cut fuel until 9400rpm; you could delay the shift to 5th by driving up to 104-105mph at 9400rpm even if the power curve is heading downwards.
///Robin
///Robin
I think most cars shut off at about 9000-9100 rpm....... did you run yours on a dyno or how do you know it shuts off at 9400?
[QUOTE]Originally posted by TrueDrezzer
[B]Actually, what's wrong with shifting at more than 9000rpm?
I read somewhere our fuel cutout was 9200rpm. Not sure if this is true or not.
XViper, whom I met in person this past weekend, thinks the 4.77's can give a supercharged S a run for its money.
I really need to get things coordinated here.
Stay tuned.
Stay tuned.
-S/C'd car has stock rear gears.
-in 0-60 mph and in 1/4 mile.
-the driver must NOT be a "slouch" in the shifting department.
Obviously, the S/C'd car with stock gearing will be able to achieve a higher top end than the non S/C'd (stock gearing) car while the 4.77 car will redline just over 140 mph. In this scenario - NO CONTEST!
When you're doing this, do you have the option to leave 6th alone so as to not affect highway cruising? Actually I'd consider something like this for gears 1-3 or 1-4 but leaving the top alone. I think if I'm at the top of the lower gears it's because I'm trying to pick up speed in a hurry, where in higher gears that's not as likely - I'm not interested in much past a ton without a roll bar.
xviper: thanks, I've never done anything in that part of a car so I'm pretty ignorant about it. Are you saying that people don't generally / can't change out the actual transmission gears, so they just change one of the drivetrain gears (further "downstream" from the engine)? That seems a shame for the reasons I mentioned before. But I guess it's a lot cheaper/easier to get at the differential.
