11,000 RPM's ?
I'm just about committed to rebuilding the head, w/ SS light weight valves, Ti seats, stronger springs, and Toda Cams. This should be under $2000 and even w/ Spoon's Ti valves it ought to be not much more than $2500, if that much. Result ought to be a head (only) that could run at 12k rpm all day. Obviously, the bottom end would have to be built too if that high an rpm would be used often or for a substantial period of time.
Thanks to Hams2000 for putting me on to Import Builders and for a ton of data he gave me.
STILL - what the hell do you do about the fuel cutoff at 8900 or whatever it is? I don't think that a VAFC would handle that. I know that the AEM PEMS would, but would hate to get into that can of worms. So - any alternatives out there?
[QUOTE]Originally posted by blaks2k
[B]I know VTEC engines are designed to shift at higher RPMs, but I find myself staying very low when I shift <5000. Is this bad for the car?
Increasing the redline by 2000 RPM is NOT just about valve springs and cams. Go ahead and do it, total waste of money.
You would require a new intake manifold, injectors, intake(s), and a new head capable of moving almost 23% more air and fuel into the combustion chamber as well. The bottom end could probably handle it but you'd have to redesign the top from scratch.
Did I mention oil circulation and the headers/exhaust?
Get real people, 11K RPM is to 9K what 9K is to 7.3K
Originally posted by BigWave10
A friend has been telling me that some folks are using motorcycle valve springs from a "R" high-rev street bike and that a S2K is capable of rev's to 11K with this and a few other minor mods. Is this non-sense or has anyone heard the same?
....NONE
[QUOTE]Originally posted by BigWave10
[B]
Continuous shifting below 4K has been known to result in causing hesitations under normal low RPM driving (sometimes bad and can happen anytime ie:engine loads up over time).
[B]
