15w 50 from Mobil One
Old Jun 3, 2002 | 02:17 PM
tiberius's Avatar
Default 15w 50 from Mobil One
Ok so I was setting out on a drive when I made a routine check of my oil. Low again (not unusual since I've done a bit of hard driving since my last change).
Go to my stash of Mobil One in the Garage - one bottle left - but I mistakenly bought the 15w 50 oil.
Was worried about adding this so I stopped along the way and put in more of the same weight usually run
Question: What would this have done? Anything? I'm guessing couldnt be that bad - 1 quart.
Also - the 15w 50 does say high performance and am guessing a higher viscousity is not all bad as the weather gets hotter up here.
Thoughts?
Old Jun 3, 2002 | 02:42 PM
SECRET AP1's Avatar
15w50 is a bit thick. I'd do another change.
Old Jun 3, 2002 | 02:49 PM
xviper's Avatar
Multigrade oils of any particular type will be more or less completely miscible with one another. If you added 1 qt of 15W50 to say, 4 qts of 10W30 that would already be in your crankcase, you would simply be averaging out your oil and numbers.
ie: you'd have about the equivalent of 11W34 oil. No big deal.
It's not like you'd have "pockets" of 15W50 oil pumping throughout your engine.
Old Jun 3, 2002 | 02:53 PM
tiberius's Avatar
[QUOTE]Originally posted by xviper
[B]Multigrade oils of any particular type will be more or less completely miscible with one another.
anthonylan
Dec 17, 2012 05:23 AM
bexiga
Feb 20, 2011 03:23 PM
Edberg
Feb 5, 2010 09:33 PM
Verik
Nov 1, 2008 09:50 AM
shox
Feb 11, 2007 04:29 PM
