16" wheels to close the gap
Old Apr 19, 2001 | 08:45 AM
ricosuave's Avatar
i was wonder what size tires would be needed to leave about a 1" gap on the stock 16" rims w/o lowering the car. does this pose any changes to performance other than a more cushioned ride?
Old Apr 19, 2001 | 08:49 AM
Tox's Avatar
Tox
You'd have to change to series 60 or 65 tires to do that. You probably would not be able to find tires with anything like the performance of the S-02s, and the increased sidewall flex during cornering would degrade the car's handling even if you could. IMO, not a great idea.
Old Apr 19, 2001 | 08:55 AM
blowns2000's Avatar
dont up the size of the tire it wont handle the way it should .youll ruin the performance ride just lower the car 1 inch it wont hurt the ride
Old Apr 19, 2001 | 08:57 AM
Unicron's Avatar
ricosuave,
Ooooohhh man...don't up size the profile of the tire!
1. It will look like you are running on donuts!
2. You are going to loose some acceleration.
Just drop the car bro!
Old Apr 19, 2001 | 09:11 AM
joe_s2k's Avatar
...and your SPEEDO will not be accurate either
Old Apr 19, 2001 | 09:29 AM
Scot's Avatar
just jack up the back of the car and get some cragers for it, then some louvers for the rear window, a bright yellow or chrome differential cover (if only) and a calvin peeing on a ford and you will have the ultimate import NOVA/Chevelle
Remember if you do get taller tires that there is not very much room up front on turning..you will smack the tire into the bumper....also..only 1/2 of the increase is going above the axle....
Scot
Old Apr 19, 2001 | 09:37 AM
Tox's Avatar
Tox
Good point. But you can get around this by going to 70-series tires and running them at 15 psi.
Old Apr 19, 2001 | 09:40 AM
cmnsnse's Avatar
You lose wheel torque also
Old Apr 19, 2001 | 10:04 AM
SFDukie's Avatar
Roy, you literally made me laugh out loud! ( I've had a tough 2 days)
Sorry to hear you aren't going to Asheville. You'll have to come out to the left coast s2kdays next year and drive my car with Janet. Heck, I'd probably even let your daughter drive, you guys are so nice
Don
Old Apr 19, 2001 | 10:16 AM
shingles's Avatar
1) more rotational mass = worse braking as well as acceleration performance
2) speedo will be off
3) odometer will be off
4) visually not appealing
5) springs are easier and cheaper.
-shing
