19" on the rear and 18" up front
There's no real advantage I can see besides looks. As long as the overall diameter is the same you're not really changing anything. But to keep overall diameter the same you're gonna look weird. You'll have more rubber up front than you will in the rear. The only way to make it look better is to go smaller overall diameter in the front or larger in the rear. Larger rear diameter will probably reduce torque and smaller front would make abs harder to activate.
Originally posted by Big Ben
Isn't ABS on the front brakes only? I don't really see a need for ABR in the rear. The front brakes are the most important anyway.
-Nick
I've been curious about this also. But I've been thinking 18's in the rear and 17's up front. The Corvette does it, and so does other cars such as Ferrari's.
Originally posted by rogerio1234
The final diameter has to be the same, otherwise you'll mess with the ABS.
225/40/18 and 205/45/17 for a year with never a problem with the ABS. I checked it
several times. The diameter difference in the tire size was .7 inches. The car looked
hunkered down because the rear wheel was one-inch larger and slightly taller. Like
most tire/wheel modifications, several factors have to be weighed when considering
the direction you're taking. Bling S2000's can ride with staggered wheel sizes and
do so comfortably. Hardcore racers would never go with that size wheels so somewhere in between sounds like where this guy wants to be. The key to making
your combo work visually is maintaing equal sidewalls, otherwise, it looks sort of
funky. Also, you'll have less stagger because it's hard to get sidewalls close (when your
overall tire diameter has an inch of difference) without closing the gap between the widths of the tire.
Well actually im into both...i am willing to give up a little performance for a lot of looks but not if it isnt worth it!
Originally posted by hyperpm
Had 18's on my car and lost some straightline and braking performance. Pretty sure 19's will do worse but from your post, sounds like you're more into looks.
S2kRob
Jan 1, 2003 04:14 PM
