1st Gear "CLUNK"
Mine clunks and grinds and whirs and whines all the time. I've no idea if any or all is indicative of a problem but with only 3900 miles on the odo, I'm not worried. It may be my demise, but I have faith in Honda
Originally posted by alexz
I have it on MY01, never thought too much about it. Should I??
Originally posted by boiler The only adjustment that I made was to make the clutch pedal stroke longer.
My 700 miles '04 is hard to shift to 1st
at a stop sometimes, it also make a "clunk" sound too. It also has ocassional 2nd gear grind. I would like to try adjusting the clutch pedal to rid of 1st gear clunk and 2nd gear grind, but I do not have the helms manual, can boiler or someone shows the details of adjusting the clutch pedal to get more travel on the pressure plate ?
Thanks
Thanks
There is a piece of shaft connecting the gearbox to the clutch. If you put the car in neutral after stopping and release the clutch, you will set the stage for the "clunk". The engine is now spinning that shaft piece. When you release the clutch, the shaft piece will slow down. If you quickly (within a second or two) put it in gear, the syncros will slow the shaft to geared drive shaft speed (which is zero when you're stopped). The noise of the shaft suddenly stopping is the "clunk".
This shaft piece weighs about 18lbs, so it's a fair bit of mass to stop.
If it annoys you to hear the "clunk", either keep the clutch in whenever you stop, or wait a few seconds after putting the clutch in before putting the car into 1st gear.
Originally posted by hoof If it annoys you to hear the "clunk", either keep the clutch in whenever you stop, or wait a few seconds after putting the clutch in before putting the car into 1st gear.
As Coral Doc mentioned, don't get carried away with this adjustment. You will want to make sure that you have no pressure on the clutch pedal linkage (it should have free play) or you will wear out the throughout bearing prematurely. This misadjustment could also cause the clutch to slip.
I would post the piece from the Helm's manual, but they are keeping a close eye on posting copyrighted material on this forum.
