2000 S2k
Old Dec 25, 2001 | 08:11 AM
Rieger328Ci's Avatar
Default 2000 S2k
I am planning to buy an 2000 S2k, I was wondering if there is anything I should be aware of for the Y2k models since its the first production year of the S2000? Thanks for all info. Hopefully I can be a S2000 owner soon!
Old Dec 25, 2001 | 08:42 AM
s2ktaxi's Avatar
If you do a search, you'll probably find:
1) a couple of TSB to watch for - transmission grind, clutch noise, boot cover for top replacement
2) rear window wear
Old Dec 25, 2001 | 08:52 AM
Tugz_S2K's Avatar
Banned
Other than what was just said, thats about it. The S2K is remarkably well built and reliable limited production car. You shouldnt have any worries buying a 2000. Just have the usuall things checked when buying a used car. Most importantly have the engine compression tested. Bad compression is a sign of an abused engine or even worse an abused car.....Good Luck
Old Dec 25, 2001 | 09:16 AM
s2ktaxi's Avatar
May not hurt to do a dyno - but do it with another car as a reference.
Old Dec 27, 2001 | 12:32 AM
bayarea408's Avatar
if you can get the '00 s2000 at a great price, just get it.
Old Dec 27, 2001 | 02:37 AM
Nachtmeister's Avatar
I own a '00 and never experienced any problems except for a cracked hood insulation due to excessive heat from track use.
The notable '01 improvements are probably limited to the free aero screen and a clock while the '02 model has been updated a bit more...
forplay
Jan 6, 2007 03:00 AM
brazielr
Mar 25, 2004 09:40 AM
aeromotive1
Mar 7, 2003 06:06 PM
lostsol
Oct 13, 2002 05:19 AM
abura
Sep 2, 2002 04:47 AM
