2002 1-2nd grind
one true grind when it was cold. I have about 700miles on it so hopefully the notchy feel will go away. I have to baby the 1-2 shift early in the morning though. The first couple of minutes after taking off in the morning is my only fear.
I have felt gears when a couple times when doing a 1-2 shift with low rpms <3000. There wasn't a sound but you could feel it in the shift knob.
I have an '02 with 4300 miles on it (in less than 2 months). I grind into 2nd quite often (probably 2~3 times per day), and it is getting worse. I think it has to be a defect, but it only does it at high RPMs. If I push the clutch in, hold it, and wait for the RPMs to fall, it shifts into 2nd fine. I can shift into any other gear quickly without any problems at all. I would like to have it fixed, but am waiting for it to get worse, so that the dealorship can experience it.
S9Krpm, where did you get your headlights cleared?
I cleared the headlights myself with the help of a friend, took off the bumper, removed headlights, used a heat gun on the silicone to separate the casement, undid 3 screws and took out the amber reflector, resiliconed the casement and put it all back together. 4hrs. Made the S look even better.
I dont feel the 1-2 grind anymore (since 2300miles and currently at 3200miles) but I definitely notice that when I shift right before what the fuel cut off which is meant to be (9200???not sure, I've never hit it) it is an extremely smooth shift.
I had another minor grind at about 3500rpm. It was just shortly leaving in the morning and the tranny is still cold.
I this only the second time but it is pissing me off.
1300kms as of today.
