2003 - no rear defroster?
Searching the forums, I've found that the rear defroster switch should be to the right of the steering column on the 2003 MY - I only have a plastic blank. Any ideas on why this would be?
I'm sure it has one! On the MY04-05 they changed the position of the switch to just after the gear lever, but I do not recall where the switch is on the 03. It should be one switch that defrosts your side mirrors and rear window simultaneously. Probably there is just a side mirror sign on the switch, no rear window!
well, first off, does it have a glass rear window? are you sure its an 03? all i can say is that its not an 03, and someone lied.
Didn't they have a rear defroster in the 02's when they switched to the glass rear window? Wouldn't make sense that early 03's didnt have it then. You are correct that it should be on the right side, just about directly behind the windshield wiper arm. Same style button as the cruise control over on the left side.
Originally Posted by s2k dre,Jan 5 2007, 07:58 AM
my 04 has it right behind the wipers.
