2006 S2000 Shifting
Old Mar 30, 2006 | 06:43 PM
  #21
efthimios's Avatar
I had an 02 for 3.5 years, now an 06...I don't notice any lag at all
Old Mar 30, 2006 | 08:32 PM
  #22
xviper's Avatar
Good enough for me.
I'm going to chalk this up to another "urban myth" or "old wive's tale".
Moral of this story .................................................. .
Don't listen to people have absolutely no basis for comparison.
Old Mar 31, 2006 | 07:47 AM
  #23
Fyrestrike's Avatar
Previous car was an '03 with 65k and 3 yrs of autox. There is no throttle lag on my new '06 but there is two things:
1) I agree with one of the above posters about a hesitation in the throttle when getting back on the gas after being off it. It seems that being harsher on the throttle cures the problem. It's just something I'm going to have to get used to. With the '03 I had the throttle cable so tight that I had to try to be smooth, with the '06 it's smooth to begin with so you can be a bit more harsh with no adverse effects.
2) There is definetely about a half inch of play BUILT IN to the connection between the gas pedal and the cable that goes to the rheostat in the engine compartment. My best guess is that is to keep from burning the TB motor out by dampening the effects of constant +.5% -.5% throttle position fluctuations. This is the only part of the DBW that is annoying me.
Overall I think they did a good job.
Old Mar 31, 2006 | 07:51 AM
  #24
2QYK4U's Avatar
If you are experiencing any lag, I would attribute it to the CDV and not the DBW.
Old Mar 31, 2006 | 08:42 AM
  #25
Dave-ROR's Avatar
So can you provide a technical explanation of how the clutch delay valve will cause these symptoms.. when the clutch pedal isn't even involved?
I described the problem and Fyrestrike confirmed that his car had it also.
Neither of us were disengaging/engaging the clutch at the time we experience the lag/hesitation.
And considering that none of the 04/05's have this problem (but have the CDV) I would have to say that your theory is incorrect. I drove an 04 just to confirm that after I noticed it.
Like I said before, it's not a big deal in my opinion and I don't mind that it's there in that one instance, but I figured it was worth noting.
Old Mar 31, 2006 | 08:44 AM
  #26
2QYK4U's Avatar
The CDV has been known to cause a lag right after shifting. This is the lag I am referring to. If you are experiencing lag at any other time, I don't know what to tell you other than I am not experiencing that problem.
Old Mar 31, 2006 | 08:50 AM
  #27
Dave-ROR's Avatar
While that's true, and I have also experienced that, the DBW does cause lag is certain cases.
I thought you were replying to Fyrestrike directly, sorry if you were not.
detonator2x
Jul 16, 2008 10:08 AM
93sho<S2000
Oct 23, 2007 12:38 PM
DJFriar
Apr 4, 2006 04:31 PM
J Roman
Oct 14, 2005 01:19 PM
Metalhead
Sep 9, 2005 11:47 AM
