2nd Gear Grind
Old Oct 24, 2000 | 07:58 PM
StudentDriver's Avatar
Does the recall mean that even tho there is no grinding problems with your car, you can still take it into the dealer and have them change it. Does the recall go for all the 2000 S2000. So let say if there is nothing wrong with the Gear right now, and after 2 1/2 years there is still nothing wrong, but I bring it into the dealer, do they still have to replace the clutch and everything.
Thanks for your help
Old Oct 24, 2000 | 08:12 PM
Unicron's Avatar
"Don't try to fix what's not broken."
I had the 2nd gear grind until Honda fixed it. But now the clutch does not grab 2nd gear as hard. What happened? Who knows.
Old Oct 25, 2000 | 03:31 AM
laster's Avatar
I have to go along with the Don't fix what ain't broke theory. If you have never had the grind it is probably a good idea to not have some tech with limited experience working on rear wheel drive transmissions playing around with your car. If you have the grind it is worth the risk.
Most people who have it (myself included) experienced it early on. I don't believe it is a wear issue. JMHO YMMV
Old Oct 25, 2000 | 03:33 AM
cdelena's Avatar
It is a TSB, not a recall. The Honda policy (that makes sense) is not to do the work unless they are sure it is a problem.
Old Oct 25, 2000 | 03:34 AM
laster's Avatar
BTW it is a service bulletin not a recall. If you don't have the grind, they don't have to fix it. (thought most dealers have been good about taking the owner's word on it) I don't know how much luck you will have trying to get your clutch replaced after 2.5 years.
Old Oct 25, 2000 | 05:07 AM
VA S2K's Avatar
Mine doesn't grind at all, so I'm not taking it in. "If it ain't broke, then don't fix it!"
houstonpv
Feb 3, 2009 06:28 PM
truekakaka
Oct 15, 2007 03:56 AM
LyNX
Jun 11, 2002 08:54 AM
redleader
Mar 13, 2001 04:22 AM
Unicron
Oct 20, 2000 04:52 PM
