2nd Transmission problem;sign of things to come ?
Old Nov 9, 2000 | 12:03 PM
Pierre S2K's Avatar
Yes, my car is in for a second transmission fix.
The first one was to cure the 1-2 grind and now it is a totally different problem for which the symptoms are :
*very difficult downshifting from 2nd to 1st.
*get a resistance(as if the brakes were on) when backing up.
*get a "thump" when letting out the clutch in neutral, with the motor running.
Apparently the dealer has seen this problem before........
Has anyone else had a similar problem ?
Pierre
Old Nov 9, 2000 | 12:37 PM
yogi's Avatar
i get a thump often when i depress the clutch in neutral...didn't think this was a problem, cause it almost feels like something is engaging
Old Nov 9, 2000 | 02:10 PM
yogi's Avatar
back to the top!
anyone else get a thump?
Old Nov 9, 2000 | 02:12 PM
cdelena's Avatar
Actually sounds a little like the failures from inadequate oiling. Have you been doing any extended high speed runs?
Old Nov 9, 2000 | 02:15 PM
Rossi's Avatar
Yes, I've had difficulty downshifting from 2nd to 1st just in the past 1000 miles or so. It's VERY tight sometimes, almost like having a lockout spring there, even when sitting still or rolling slowly. I've had the status quo grind from 1st to 2nd about four times now at high RPM (embarassing, isn't it?), and I've also had a problem going from 2nd to 3rd a few times now. Sometimes 3rd either won't engage or is very tight, and a couple of times it has also had the grind like 2nd gear. Scary.
None of the other gears have any problems at all including reverse, and I should also note that I push my car to 9K pretty regularly (ah, the joys of living in the wide-open countryside of north Alabama). I'm just waiting to get a few more miles on the tranny before I have it taken apart to see if anything else breaks or gives me problems between now and then. I wouldn't want the box opened up more than once by the dealer (too much room for error), so my philosophy is to endure the problems for a while, then fix'em all at once.
No clutch problems or strange differential noises yet (whew), but I never dump the clutch from a standing start either. I have about 6500 miles on her since 8/31/00 (just over 2 months).
Old Nov 10, 2000 | 05:56 AM
Pierre S2K's Avatar
No extended high speed runs on the street for me but some mild track use however.
BTW I couldn't get from 2nd to 1st even with heel & toeing !
...getting the car back this afternoon with a new clutch which I have to pay for, but for which I shall take Honda to small claims court to get back....
I'll keep the board posted.
Pierre
macdaddies911
Feb 21, 2012 03:56 PM
TheCoffeeClub
Apr 19, 2008 05:37 AM
ben6600
Nov 20, 2006 11:11 PM
Sickdayracing
May 2, 2005 03:07 PM
RS2000
May 9, 2001 09:16 PM
