4.56 gears
Old Nov 3, 2005 | 08:23 AM
rikhemi's Avatar
Default 4.56 gears
Wondering other than the gears, any extra parts(cost) that are associated with getting 4.56 gears or even 4.77 gears since I heard 4.77 gears fit like stock to our housing.
Thanks
Old Nov 3, 2005 | 08:29 AM
s2kVABeachCruiser's Avatar
I can name a few:
Crush sleeve
Inner bearing
Lock nut
Old Nov 3, 2005 | 08:30 AM
xviper's Avatar
Any gears that are the same dimensions as our stock gears will fit "like stock". This doesn't eliminate the need to get extra stuff. Even if you got another set of OEM ring and pinion set, you would still need to change stuff.
Inner and outer pinion bearings, crush sleeve or 2, shims of a thickness that you will not know till the calibration is under way and assorted bolts and parts that may not survive the disassembly process.
Old Nov 3, 2005 | 09:22 AM
spider2k's Avatar
Active Streak: 30 Days
the 2 oils seals as well. theres a list in the thread that announces the 4.56.
Old Nov 3, 2005 | 09:45 AM
Emil St-Hilaire's Avatar
Interested to buy gears,already installed in diff.from Rick's.!!?
Possible???
Requiem
Feb 14, 2010 09:08 PM
S2Kmonkee
Sep 25, 2009 08:05 PM
s2kbtos
May 30, 2007 05:00 AM
kinetica
Sep 24, 2005 12:17 PM
