400,000 Miles and Counting!
Old Apr 19, 2019 | 07:46 AM
slalom44's Avatar
Top Answer: 1
Default 400,000 Miles and Counting!
I finally did it. I made it to 400,000 miles. Original engine and tranny. My '03 NFR still runs and looks great.
Old Apr 19, 2019 | 07:49 AM
Carbon Blue's Avatar
wow! Post pics of the car! Id love to hear a break down of your maintenance list and parts replacement along with any other interesting tidbits. Daily driver im assuming?
Old Apr 19, 2019 | 10:57 AM
cgarrett23's Avatar
Wow...that's impressive!
Old Apr 19, 2019 | 11:45 AM
noodels's Avatar
Old Apr 19, 2019 | 12:17 PM
Hockey's Avatar
And here I thought me turning 300k on my '00 Silverstone this week was impressive.
Congrats.
Old Apr 19, 2019 | 12:34 PM
NNY S2k's Avatar
Levi
Old Apr 19, 2019 | 01:17 PM
rpg51's Avatar
Amazing. What is your maintenance routine?
Old Apr 19, 2019 | 01:52 PM
TRDLiquidSilver's Avatar
Congrats!
i echo what others have said. please tell us what you did to get to 400k?
Old Apr 19, 2019 | 01:53 PM
Congrats.
my 200k which i'm 3k away from will also pale in comparison.
Old Apr 19, 2019 | 03:05 PM
slalom44's Avatar
Top Answer: 1
Thanks, for the compliments. As you might expect, most of these are highway miles. The trick is to keep it running reliably so I can take it on long trips where I rack up the miles.
I'm still on the original TCT, exhaust, O2 sensors and radiator. Besides the obvious required periodic maintenance, I have replaced the following:
  • Starter
  • Alternator Brushes
  • Fuel Pump
  • Idler pulley & tensioner pulley
  • Wheel bearings (actually the entire hubs)
  • Struts & springs
  • Clutch (once at 330,000 due to bad throwout bearing)
  • PCV
  • Windshield (three times)
  • Coil packs
  • Brake caliper
  • A/C Compressor
When the car was a year old and had 6,000 miles I installed an Amsoil Dual Remote Bypass Filter as well as a prelube pump. Here is a link to my setup. I gradually extended my oil change intervals up to 40,000 miles since the filter did a great job of keeping my oil clean. Here is a thread showing my latest UOA.
The car still runs great. It burns a lot more oil than it used to, but I'm not convinced it's caused by worn rings. No puffs of blue smoke at startup or acceleration. I've had to flush the clutch fluid a few times to keep it from losing fluid, but the master and slave cylinders are still original.
Last edited by slalom44; May 1, 2019 at 01:53 PM. Reason: added A/C compressor to list
