400lb limit?
Old Jun 19, 2002 | 08:44 AM
wjmb's Avatar
When I moved from Mississippi to VA Beach I had my '01 loaded to the hilt: full trunk, full passenger side with cargo. Probably in the 500lb+ region. I felt no adverse effects. Not even on high speed highway bumps/expansion cracks. Handling was about the same; accel maybe a little slower. Then again, that's probably cause I only weigh 130.
Old Jun 21, 2002 | 08:57 AM
TXRacer's Avatar
I weigh 230lb and have had a 250lb+ friend regularly in my car... The rear tires slide around a lot less, but that's the only difference I've found.
Old Jun 21, 2002 | 09:41 AM
jelliotlevy's Avatar
I'm 6 foot 2, 215 lb, and my son is 5 foot 11, about 200. Even with my 125 lb Significant Other plus luggage, I am at or above that theoretical limit. You certainly want to be have 32 psi or greater tire pressure under such conditions. I believe that when you are at or above the load limit, the tires are in a region where heat and flexing are more punishing to treads and cords; higher pressures help mitigate the extra stresses. You probably want to be careful not to overdo it under conditions of high heat and high speed, but then you really shouldn't be barreling along at 100 mph across the desert in 120 degree heat anyway.
If I remember correctly, that was a source of the problems with the unfortunate Firestone tires installed on the Ford Exploder. Ford had recommended lower tire pressures to soften the trucklike ride, and most of the catastrophic failures were occurring under high speed hot weather conditions, perhaps also with heavy loads playing a role.
Old Jun 21, 2002 | 09:58 AM
germ79's Avatar
Very informative... thank you.
J
Old Jun 21, 2002 | 05:17 PM
velocity's Avatar
I'm curious why anyone on the "large" size would own the S2K! Is comfort not important??
Old Jun 22, 2002 | 12:49 PM
Edge's Avatar
Originally posted by jelliotlevy
plus luggage,
HA!
Old Jun 22, 2002 | 01:22 PM
DaveZ's Avatar
Don't forget that the difference between a full and empty gas tank will be over 50 pounds.
Old Jun 22, 2002 | 03:29 PM
germ79's Avatar
Surely fuel isn't supposed to be considered as part of the 400lbs?!
Old Jun 22, 2002 | 06:59 PM
Destiny2002's Avatar
Based on what I've read, the 400 pound rating is primarily to keep the load within the tire's speed and load rating. The tire's load rating on the blackwall is at the max psi, but the car manufacturer's spec is lower.
If you know your car will be heavily loaded, bump up the tire pressure closer to the maximum stamped on the sidewall, and don't drive at sustained high speed.
Old Jun 26, 2002 | 03:34 PM
TXRacer's Avatar
[QUOTE]Originally posted by velocity
[B]I'm curious why anyone on the "large" size would own the S2K! Is comfort not
VOLGUY
Mar 16, 2004 07:58 PM
Bernie Lomax
May 18, 2002 10:02 AM
loyed
Jan 5, 2002 02:21 AM
dillehay
Feb 25, 2001 09:05 PM
