5th Gear Problem
Old Jul 14, 2004 | 05:58 AM
J11ESY's Avatar
Default 5th Gear Problem
Hi guys, need some of you knowledge to help me out.
The problem I am having is changing into fifth gear (all others are fine) it is really stiff and the other day it jammed between 5th and neutural, any ideas what would cause this, as I can't think what it would be seems it is only one gear that has the problem?
Cheers in advance
Ilesy
Old Jul 14, 2004 | 08:01 AM
Faysal's Avatar
wats da mileage on ur car? n wat model is it? Well wen da car is cold and not warmed up ... gears grind sumtimes..
I have never had problems with 5th gear...only sumtimes 2nd gear grind.. but dats it. Take it to the dealers if its still under warranty.
Old Jul 14, 2004 | 08:47 AM
fly_S2K's Avatar
Do you "skip shift" often? Like shifting from 4th to 6th rather then go through 5th? Read this thread, it might be the answer to your problem. https://www.s2ki.com/forums/index.php?showtopic=219070
Ks320
Jan 8, 2009 06:04 AM
VTECturbo04
Jan 19, 2006 12:20 PM
Wildncrazy
Apr 14, 2005 02:14 PM
J11ESY
Jul 20, 2004 04:36 PM
Rx man
Jan 19, 2002 07:37 AM
