5th Gear Problem
Old Jul 14, 2004 | 06:06 AM
J11ESY's Avatar
Default 5th Gear Problem
Hi guys, need some of your knowledge to help me out.
The problem I am having is changing into fifth gear (all others are fine) it is really stiff and the other day it jammed between 5th and neutural, any ideas what would cause this? as I can't think what it would be, seems it is only one gear that has the problem?
Cheers in advance
Ilesy
Old Jul 14, 2004 | 07:00 AM
twohoos's Avatar
https://www.s2ki.com/forums/index.php?showtopic=139607
See davepk's post.
Old Jul 15, 2004 | 05:10 AM
LewKeim's Avatar
I resently had the same problem.
After posting and receiving the same link I have cured the problem - Thanks to all....
What I was doing wrong was while the clutch is engaged slowly but very forcefully pushing into 5th. After reading the thread I tried quickly jabbing it into 5th ant it engaged. It now is a little hard to disengage but at I continue to shift in and out I think it is improving.
The only think I did to bring about this problem would have been a couple of shifts from 4th directly to 6th.
Old Jul 15, 2004 | 05:41 AM
J11ESY's Avatar
Cheers guys, this has been a big help, been trying it today and can feel it loosening so hopefully should in time be all good again.
Ilesy
Old Jul 17, 2004 | 06:02 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Shifting from 4th to 6th will in no way harm the car, or bring about problems.
Old Jul 20, 2004 | 04:36 PM
LewKeim's Avatar
Well I never thought 4th to 6th would be a problem ...but the link in this thread leads to someone who says differently???
eastonh477
Feb 21, 2011 08:18 PM
intcoverup
May 5, 2007 09:45 AM
J11ESY
Jul 14, 2004 08:47 AM
S2K01
Mar 11, 2002 05:23 AM
