9K AP2
Old Oct 10, 2006 | 05:40 PM
  #21
sodaking663rd's Avatar
Originally Posted by DaveOnLI,Oct 10 2006, 06:36 AM
F22 has increased stroke and therefore has higher piston speeds. There are a few people that have AP2 engines running AP1 ECUs which take them to 9000 RPM. However the power does drop off somewhere after 8000 and does not continue to climb to 9000.
bingo. higher piston speeds is the reason for the lower redline. honda lowered the redline for a reason so use caution...it wasn't just to agrivate us ap2 owners
Old Oct 10, 2006 | 07:01 PM
  #22
Chris S's Avatar
Originally Posted by bluegas68,Oct 10 2006, 09:24 AM
As in F1, im sure those engines are larger than 2.2 and they rev WAY HIGHER than 8K.
If you're OK w/ accepting an engine life as long as an F1 car's, I'm pretty sure you can raise the rev limit to 9K.
Old Oct 10, 2006 | 07:47 PM
  #23
RED MX5's Avatar
F1 motors displace 2,400 cc's and have 8 cylinders, so they have a stroke similar to a 1,200 cc I-4. IOW, the piston speeds are lower at 9k than an AP1, becaue the stroke is a LOT shorter. At 18k the piston speeds are similar to an AP1 at 9k.
Of course the valves still have to open and close twice as fast when the motor spins twice as fast, and the system they use to close the valves (it uses air pressure) only last two races (like the rest of the motor). Not great for a daily driver.
Old Oct 11, 2006 | 05:48 AM
  #24
AlX Boi's Avatar
This project sounds really expensive. Anyone have an estimation on the cost?
Old Oct 11, 2006 | 07:56 AM
  #25
K-Lo's Avatar
^^^ yep! in theory, the "spring type" valvetrain starts to fail at 18,000 rpm. the oscillations would exceed the stress point of the spring regardless if it's titanium or not. that is why they rely on pneumatic (air) type system.
rhouck
Feb 7, 2013 07:34 AM
hypforlife32
Jul 27, 2010 06:01 AM
qbmurderer13
Oct 20, 2007 10:13 AM
Whitedeon8
May 26, 2007 09:23 AM
