about to dyno the s2k w/ 4.77
Old Jun 4, 2006 | 08:32 AM
AllStock27's Avatar
Default about to dyno the s2k w/ 4.77
I know with a stock setup people suggest to use 4th gear, but for a 4.77 setup, should it b on 5th? Thanks for your input.
Old Jun 4, 2006 | 08:44 AM
xviper's Avatar
I'm pretty clueless on the matter of which gear, so I won't comment. However, when you're done, I'd like to see what you get. Did you get a "pre-gear" dyno? I don't think you'll see any change in WHP, but some say that you might see a slight increase in torque with the gears.
Old Jun 4, 2006 | 08:51 AM
Sideways's Avatar
Fourth would be preferable.
The gear factor is 6.42 for 4th and 5.37 for 5th when using 4.77s. Who is doing the dyno and what type of dyno is it?
Old Jun 4, 2006 | 08:55 AM
AllStock27's Avatar
not too sure what a pre-gear dyno is... i believe there r a couple of dynos in my area.. i know one is a dynojet, another a mustang... what is a pre-gear dyno?
Old Jun 4, 2006 | 08:58 AM
xviper's Avatar
Before you installed the 4.77s.
Old Jun 4, 2006 | 10:03 AM
gomarlins3's Avatar
They did mine in 4th gear after I told them the 4.77's were in there.
Old Jun 4, 2006 | 10:47 AM
RWD_RCKT's Avatar
In the "old" days of 4speed top loader FORD's, 4th gear was a 1:1 ratio (mainshaft had 4th on it so it was a direct link right through the transmission). This gear had the least amount of mechanical loss, which would give you the most accurate (translated as HIGHEST!) indication of RWHP. I don't know which S2000 gear, if any, has that designed in. I think the rule of thumb of 1:1 ratio (or the closest gear to it) has just stuck.
But to make a long story short, a differential gear change would be inconsequential (mechanical losses between swapping differentials being equal), your vehicle speed would just be slower on the dyno.
Old Jun 4, 2006 | 12:05 PM
Elistan's Avatar
Old Jun 5, 2006 | 08:53 AM
AllStock27's Avatar
pre-gear dyno.. ahhh im stupid. thought it was some type of dyno or something. lol but unfortunately i haven't dyno'd her yet prior the SC install.. I'm just waiting for the testpip/exhaust n i should b all set. I'll post my dyno on the FI forum as soon as i get it done, possibly sometime this week or nxt week.. just need to get the boost guage and the local exhaust shop fabricate a test pipe for me..
Old Jun 5, 2006 | 09:02 AM
slimjim8201's Avatar
I hope no one has the misconception that the gears will net you horsepower on a dyno...
