Adding water to OEM Panasonic Battery...
Old Feb 16, 2009 | 10:31 AM
GranPrix's Avatar
Thumbs up Adding water to OEM Panasonic Battery...
Has anyone ever looked at the meter on the OEM Panasonic battery and filled it with distilled water?
The meter has 3 levels:
Blue: Ok
Red: Distilled Water
White: Replace
Old Feb 16, 2009 | 02:36 PM
GranPrix's Avatar
Nobody checks their battery?
Old Feb 16, 2009 | 02:46 PM
Apex Surgeon's Avatar
what's a battery?
Old Feb 16, 2009 | 03:18 PM
00S2K01S4's Avatar
Aren't these maintenance free? I look at it but never needed to add water until it died.
Old Feb 16, 2009 | 03:26 PM
2slow2Bfurious's Avatar
yeah, i added water(distilled) to the battery, it does nothing, I replaced it with a Die Hard.
Old Feb 16, 2009 | 03:44 PM
mikegarrison's Avatar
These are supposed to be sealed batteries. I'm not even sure how you would add water. And by the time you would need to, it probably indicates that the battery has developed a non-recoverable issue.
Old Feb 16, 2009 | 03:45 PM
GranPrix's Avatar
Really, well I guess mine will die with-in the next couple of months.
Old Feb 16, 2009 | 03:46 PM
GranPrix's Avatar
The indicator on the battery comes off like a screw, and just pour the water in.
Old Feb 16, 2009 | 04:13 PM
Ah! Thanks. I guess I never looked at it hard enough.
Old Feb 17, 2009 | 01:51 PM
YucA's Avatar
If you catch the low acid level early, you can properly add water into it and extend the life as the plates arent bare and wont cause a short.
If you ran the life of the battery, or are close to its death then adding water wont do anything to help it.
