Adjustable pedals - possible?
Old Aug 15, 2003 | 06:25 PM
TheCryofMankind's Avatar
Default Adjustable pedals - possible?
Does anyone know if it is possible to move the pedals closer to the driver? Or better yet, has anyone tried this before? Not that many people would, but still - stranger things have been done.
Thanks for any input.
Old Aug 16, 2003 | 12:24 AM
honda9krpm's Avatar
You can adjust the brake and clutch pedal back and forward. I am not sure about the go pedal
Old Aug 16, 2003 | 02:04 AM
lachambers's Avatar
I installed a piece of 1 inch rubber under the clutch pedal so it is a little closer to me when the brake and gas pedals were at the correct position.
I drilled out the three rivets and installed the rubber piece and reinstalled the peddle with three new matching long machine screws with nuts....
Works great.
I didn't want to change the setup under the IP so if I sold the car all I had to do was remove the rubber piece.
Hope this helps.
Old Aug 16, 2003 | 07:43 AM
honda9krpm,
How can you adjust the clutch and brake?
Thanks
Old Aug 16, 2003 | 08:55 AM
HI SPEEDR's Avatar
Wear elevator shoes!
Old Aug 16, 2003 | 02:43 PM
honda9krpm's Avatar
Originally posted by TheCryofMankind
honda9krpm,
Thanks
Crawl under the front dash, so that you will be looking up in the sky, with 2 sets spanner of 9 and 10mm.
You should see a number of bolts at the top of the clutch and brake. They are very easy to play around with, simple and you will soon figure out what to do. Dont be afraid to adjust them.
Have a go and if you need more help I will fish out some pics for you
PwetNgManok
Vancouver Island
Mar 26, 2014 04:43 PM
Kobeirving
Sep 10, 2013 08:49 PM
cupracing
Jun 7, 2011 03:26 AM
nwk00
May 30, 2003 11:11 AM
